Re: Read array from .ini file
It is possible read a ini file with duplicate names on keys?
Example:
menu =first
        subMenu =Temperature "0.5;5;1"
        subMenu = Pressure "0;5;0.4852"
        subMenu = Flow "0;5;1.2350"
        subMenu =Mass "Serial"
I always get the same value for all key 'submenu'.
Labiew show me:
[Section]->menu
[key]->      subMenu =Temperature "0.5;5;1"
[key]->      subMenu = Temperature "0.5;5;1"
Always the same value
Message 1 of 13
(5,499 Views)
Hi jawier,
no, you can't have duplicate keys (with different values) in one section!
One solution would be to keep an index in the key name like submenu01, submenu02, …
Message 2 of 13
(5,496 Views)
Example:
menu =first
Labiew show me:
[Section]->menu
The ini function will always take the first match, so no.
What you could do is have a key for Submenu with a list "submenu = temperature, pressure, flow, mass"
Read this list and then read in those keys "Temperature = 0.5;5;1" and so on.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 13
(5,491 Views)
Another alternative is to have the section submenu, get the key-list and read all those keys
[submenu]
Temperature = "0.5;5;1"
Pressure = "0;5;0.4852"
Flow = "0;5;1.2350"
Mass = "Serial"
Qestit Systems
Message 4 of 13
(5,487 Views)
Thanks. But the .ini file is from another manufacturer, and i can not modify it. (I would do it but is very hard mod all files for all machines).
Message 5 of 13
(5,442 Views)
Hi jawier,
then you need to implement your own parser.
Read the ini file as simple text and use MatchPattern (and similar) functions!
Message 6 of 13
(5,436 Views)
It's possible using the OpenG Read Section Cluster function. The trick is to enclose it in a cluster and to unbundle it after the section cluster is read.Here is an example of how I use it:
In the ini file:
[runs-1-2]
data.<size(s)> = "3"
data 0.RunNumber = "1"
data 0.veloc = "60"
data 0.accel = "61"
data 0.targetPos = "3723"
data 1.RunNumber = "2"
data 1.veloc = "60"
data 1.accel = "61"
data 1.targetPos = "-4500"
data 2.RunNumber = "3"
data 2.veloc = "60"
data 2.accel = "61"
data 2.targetPos = "3723"
Loading code:
Ben64
edit: of course you will need to modify the ini file to fit this pattern, if you can't then you will have to parse the file as already said.
Message 7 of 13
(5,427 Views)
That doesn't look like a standard config (ini) file.  You probably have to parse it out yourself.
Bill
CLD
(Mid-Level minion.)
Message 8 of 13
(5,412 Views)
@GerdW wrote:
Hi jawier,
I've seen someone parse this out in a WHILE loop where they started with Test00 and use the [i] in the WHILE loop as a suffix (with leading zero).  The parameters for each test were indexed into an array.  You knew you were done when it couldn't find the key, so you threw out the last element in the array.  That way, you didn't even have to know how many tests there were.
Bill
CLD
(Mid-Level minion.)
Message 9 of 13
(5,408 Views)
@billko wrote:
@GerdW wrote:
Hi jawier,
I use Get Key Names and then iterate over the keys.  If necessary, I can apply a filter with a FOR loop.
GCentral
Message 10 of 13
(5,386 Views)
