09-27-2011 01:03 PM
How can I re arrange the elements of a 1D array? e.g. A B C D E F G H ---> A B E F C D G H
Thanks!
09-27-2011 01:21 PM
You can use the functions Delete from Array and Insert into Array. You might also be able to use the In Place Element Structure to minimize the memory footprint of the arrays.
09-27-2011 01:27 PM
Simply use the "Delete From Array" and "Insert Into Array" VIs. See attached.
09-27-2011 01:31 PM - edited 09-27-2011 01:45 PM
Since the size of the array does not change, delete from array and insert into array should probably not be used for performance reason.
09-27-2011 01:47 PM - edited 09-27-2011 01:47 PM
Here are two solutions that operate "in-place" with respect to the large array. Pick one (top or bottom).
09-27-2011 01:47 PM
Thanks everyone, that solved it. It was a simple 1D array with values listed above @ altenbach, thanks 🙂
