Read User1 switch from RT at cRio-9047
I try to read the state of "User1" button located on the cRIO-9047.
For other RT targets i have used "RT Read Switch.vi" found in NI_real-Time Target Support.lvlib.
But now when i using the same code i get Error code -1.
So my question is, how do i read the User1 switch state [on or off] from my RT target?
(291 Views)
Accepted by tokar
Found this and modified it to work.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGMoSAM&l=sv-SE
Seems like my cRIO-9047 dont have all System Hardware functionality.
So i only using the first value witch is the User1 swtich state.
It works, but maybe someone can share other solutions, please do.
(254 Views)
Hi tokar,
instead of using ArraySubset to get a subset of exactly one element you could use IndexArray instead!
Then you also don't need the FOR loop and the IndexArray after the loop…
(247 Views)
