Read from Spreadsheet Only Reading 1st Column
I want to search for certen organ using a control in the front panal i.e Esophagus (because there are more than one organe in the same file) then read the data for that organ as in the attached image. Wat is between the organ name and the data is not important for me. What are you suggestions?
Message 11 of 15
(1,410 Views)
Do not send us pictures (jpg). SEND US THE TEXT FILE
Omar
Message 12 of 15
(1,385 Views)
Here is the text file. I used to have problem loading it due to extension error. i save it again with different name and I hope it will work
Message 13 of 15
(1,377 Views)
There are a number of ways to this depending on what you want.
This should give you a start of how to parse the data.
You should be able to figure the rest.
Omar
Message 14 of 15
(1,369 Views)
Thank you very much Omar. I really appreciate you time and expertise. You deserve big cudo from my side.
Message 15 of 15
(1,349 Views)
