05-05-2009 08:13 PM
05-05-2009 09:17 PM
Hi There,
I am also trying to get some kind of progress bar in my front panel. My program has six steps and i used "flat sequence structure" for each step. I am wondering is there a way to use slide on front panel and increment its value after each step. Also is there a way to use string indicator on front and change input when data progress to next flat sequence structure. I tried using progress bar from NI website but it works with for loop only and i do not have for loop in my program.
Thanks in advance
Yogesh
05-05-2009 09:44 PM
12-10-2009 01:06 PM
I used the vi that you provided but it copied the same files twice
Can I know where did I do wrong? or did I misunderstood something?
12-10-2009 10:27 PM
I tested its not doing as you mentioned.Check the attachment.
Note: Dont keep the VI in the same folder, where the files need to concatenated.
12-11-2009 08:36 AM
hrmm.. this is weird. I still get abcdefabcdef
I shouldn't be getting that, but only abcdef, right?
12-13-2009 08:48 PM
11-20-2010 02:53 PM
I know it has been a while since this topic has been discussed, but I have a similar problem. I have several thousand .txt files which I need to analyze (RMS and mean power frequency, specifically) and write to a single .txt file. I would like to be able to perform a batch read, where the program reads all of the files in the folder, and appends them to a single spreadsheet. It would save me a lot of time if I didn't have to continuously read from spreadsheet and write to spreadsheet over and over. I have attached the VIs I am using. I would really appreciate it if anybody could help me out...spent a lot of time trying to figure this out.
11-21-2010 01:54 AM
I don't understand your comment how "it would save me a lot of time if I didn't have to continuously read from spreadsheet and write to spreadsheet over and over."
In what way would it take a lot of time? If you feed a list of filenames into a For Loop as an Array of Paths, LabVIEW does all the work for you. It probably won't take any longer than reading one large file.
11-21-2010 02:45 AM - edited 11-21-2010 02:47 AM
Hi this is an example that does the same. It reads the text files and saves them to a Spreadsheet file. Its as simple as you can get. The file is saved in the folder containing the VI.
After reading Ravens reply: Yeah come to think of it, LabVIEW doesnt care if you give a 100 files to read or one big file. It should have any problems reading it.
PS: Thanks to Baji since i used his uploaded zip file.
