Read the pulse from the flow meter.
Hello, I'm Vanta. This is my first time working with the NI instrument and LabView. Despite having an oval gear flow meter from Badger Meter and indicator, the indicator does not show the flow correctly. What is the best way to read the pulses directly from a flow meter?
There are five wires on the flow meter:
1-Green (Pulse output)
2- Brown (Ground)
3-Yellow (12 v DC)
4- Reed Switch
5- Reed Switch
The following DAQ is available to me:
1- NI USB-6221
2- NI cDAQ-9174
NI 9215
NI 9203
NI 9263
(912 Views)
Hi this is Mehrzad, first time working with the NI instrument and LabView. Despite having an oval gear flow meter from Badger Meter and indicator, the indicator does not show the flow correctly. What is the best way to read the pulses directly from a flow meter?
2- Brown (Ground)
3-Yellow (12 v DC)
4- Reed Switch
5- Reed Switch
1- NI USB-6221
2- NI cDAQ-9174
NI 9215
NI 9203
NI 9263
(915 Views)
Please prove you're a real person and not some spam bot - you posted the same content with a different name here - https://forums.ni.com/t5/LabVIEW/Read-the-pulse-from-the-flow-meter/td-p/4295592
Santhosh
Soliton Technologies
(903 Views)
when I posted it I did not notice any confirmation for it. so I thought it was not posted then tried to post it again.
sorry for inconvenience.
(822 Views)
