Reading Data From Agilent 34401
The left column is the loop iteration number.
Message 11 of 23
(2,637 Views)
Accepted by topic author cnoyes23
Use the simple "Write to Spreadsheet" VIs. (They have a slightly different name in 2015). I have it set up for comma separated (.csv) but you can change the delimeter to whatever you want. This is a snippet so you can drag it onto the block diagram and play with the code.
Message 12 of 23
(2,627 Views)
Thank you. This might be an overly simple question but what is a delimeter?
Message 13 of 23
(2,621 Views)
Also would this structure still be valid if I'm trying to write multiple columns of data values for each loop iteration?
Message 14 of 23
(2,614 Views)
Delimeter is what separates your data along a row.
Comma: Data1,Data2
Space: Data1 Data2
Tab: Data1     Data2
Yes, if you have another single data point for each loop you can expand the "build array" node and wire it in.
Message 15 of 23
(2,608 Views)
For the pink box that says point, would you know what item that corresponds to? I'm looking for it but I can't find it.
Message 16 of 23
(2,600 Views)
That's just a text header that I wrote to the file first. You can change the column, or expand the array horizontally, to change what text is written as a header.
Message 17 of 23
(2,596 Views)
So does this write to excel or is this something I could also open in Notepad, for example (like the images I sent)?
Message 18 of 23
(2,587 Views)
You can open .csv or .txt files in notepad. If you ever do want to write to an excel file, make sure to use the report generation toolkit, not the write to spreadsheet functions.
Message 19 of 23
(2,584 Views)
Thanks for your help. The data is now nicely written in columns. One final question. The numbers only go to three decimal places. Is there an easy way to extend that?
Message 20 of 23
(2,532 Views)
