Reading TDMS Channels Property
Hi
I managed to read TDMS channel length property at channel level using 'NI_ChannelLength' property name. Although in the file, it is called 'Length'.
I wonder if there is a mysterious name for 'Channels' property which gives number of channels in each group at group level.
In worst case, I may have to write and then read it back. But I wanted to keep TDMS file clean and not duplicate field which already exists!
Any comments?
Cheers
K Waris
ATE and Labview Consultant
https://www.easybodge.com
(2,991 Views)
Accepted by k-waris
Just use the TDMS List Contents, and provide the name of the Group.  It will return the names (and therefor the number) of channels in that group.
(2,982 Views)
