Reading boolean array one by one
tan0709_0-1716200048010.png I want to run a piece of code if monitor resolution is less than 1920 X 1080. I was trying with variant to convert the array of Boolean values. Actually, I don't know what I did there, could you please help?
(466 Views)
R-click the Less than and select Compare aggregates and you have a better starting point.
Qestit Systems
Certified-LabVIEW-Developer
(453 Views)
You are converting to a boolean, not an array of booleans. You also have a glaring race condition such that the value property is read well before the terminal receives new data. The use of variants and "array element value" properties shows a complete lack of understanding.
Please attach your VI so we can have a look.
You are comparing two values, so there are four different outcomes: Both are smaller, H is smaller, V is smaller, none are smaller.
(418 Views)
Accepted by tan0709
See if this can give you some ideas....
Connect whatever is appropriate in your scenario to the case structure.
(400 Views)
How about if I have two monitors with different resolution?
(343 Views)
You can loop over the pink array (autoindexing on a FOR loop!) and process all in the same way. Currently I index out the first element (monitor), assuming there is only one.
How you deal with the result is up to you, because there are many possible results (first is larger, both are larger, etc, etc.)
(329 Views)
