Reentrancy bug in LabVIEW 2024 Q3 with backsaving
Thanks.  Filed new Service Request 03364720 echoing the behavior reported in this thread.
Message 11 of 16
(271 Views)
Nate@UT wrote:
I've downloaded the OP's example project and confirmed that the described behavior is the exact same as the one I've been struggling with (I used 2023 files and 2024 app).
No need to file a redundant bug report or post different code.  Rather, I'd just like see NI provide a fix for it ASAP... is there any way to "upvote" on the existing bug report?
NI is really opaque about this stuff, I didn't get a link to an issue page or a fix date or anything, just the number. And if I hadn't chosen to post it, you wouldn't know it was a confirmed bug.
Message 12 of 16
(261 Views)
Maybe i misread/misunderstood, but is it the same behaviour if you do a manual "save for previous" or just the automatic version?
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 16
(247 Views)
I have confirmed that the bug happens if both cases if you either:
a) create a reentrant VI in LV2024 and then manually back-save to a v2023 file, or
b) open a reentrant VI which was originally created and saved in LV2023 and run it in LV2024.
The issue happens when you've modified and saved the 2023 reentrant VI from within LV 2024 editor, but haven't yet closed the project and reopened it.  If you open the project without making modifications in the reentrant VI, the behavior is correct.  But that correct behavior disappears as soon as any modification is made and the VI is re-saved.
Message 14 of 16
(232 Views)
It also happens when opening 23 code in the 24 IDE and doing a mass compile. I didn't touch anything before mass compile.
Actor Framework
Message 15 of 16
(214 Views)
@avogadro5 wrote:
This is now bug #2937381
Seems to be fixed in 2025 Q1 despite not showing up on the bug fixes list https://www.ni.com/en/support/documentation/bugs/25/labview-2025-q1-bug-fixes.html.
Message 16 of 16
(64 Views)
