Remote Development Application Error
I am getting an NI LabVIEW Remote Development Application Error while running on a cRIO using LabVIEW FPGA software, see attachment.
What is the error?  Where is the Application Log?  I do not see anything in MyDocuments\LabVIEW Data\Remote Development directory.
Paul
(3,362 Views)
Attachment added
(3,360 Views)
Hi Paul,
Which CompactRIO are you running, and which version of System Configuration do you have installed on that cRIO? There is a known issue where this error occurs when System Configuration 15.3 is installed with Remote Development 15.0 on a 908x Windows Embedded 7 Controller. We apologize for the inconvenience and are working to fix the issue.
For the time being, reverting to an older version of System Configuration should allow you to connect to your cRIO.
(3,310 Views)
Yiran,
We are running a cRIO-9081.  Our Systme Configuration is 15.3.  I do not know how to get the Remote Development Version.
We still can connect to the cRIO, we just sometimes get this error.
Paul
(3,301 Views)
Hi Paul,
Thank you for the update. This issue should be resolved with with one of the future releases of System Configuration.
(3,262 Views)
(3,257 Views)
