Remote control using attached computer-baby level HELP
Do you have either the USB-GPIB or GPIB-Ethernet adapters? If so I would try and talk to the instrument with them and see which one you can implement.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
Message 11 of 25
(829 Views)
Hi CC,
No we dont we need to buy them I thought to buy prologix bridges each cost around 200$.
Ben
Message 12 of 25
(817 Views)
Well, if you go with that hobbyist approach, you cannot use any standard instrument drivers because the prologix is not a true GPIB controller as far as the system is concerned. Since your time is 'free', I suppose that can be justified but keep in mind that support is going to be limited.
Message 13 of 25
(813 Views)
what do you suggest?
Message 14 of 25
(803 Views)
Are you suggesting that if I use prologix GPIB-USB then the instrument manufacturs Labview driver wont work, or I will need to hack it ?
Ben
Message 15 of 25
(798 Views)
Both. A driver will not work until you hack it. The prologix requires you to add serial communication code. Look at their website for the LabVIEW examples and directions for modification.
USB controllers from NI, Agilent, Keithley, etc, appear to the system as actual GPIB controllers. The prologix appears as a serial port so all of the GPIB/VISA Writes/Reads need to be changed.
Message 16 of 25
(795 Views)
And do you think I sould go for the USB-GPIB option?
Ben
Message 17 of 25
(777 Views)
Unless the instrument is at some distance from the pc, yes.
Message 18 of 25
(772 Views)
What about Advantech?
Thank you for the help,
Ben
Message 19 of 25
(743 Views)
Hi Ben,
It looks like Advantech does have a LabVIEW driver. However, I do not have one of these devices on hand to test. I can't say with certainty whether it will show up or not as a GPIB resource.
I am assuming you are talking about one of these?
http://www.advantech.com/products/USB-4671/mod_7DCA545B-4AD6-482A-9227-1DB40DACB124.aspx
Joey S.
Senior Product Manager, Software
Message 20 of 25
(687 Views)
