05-06-2012 10:06 PM
How do i remove the NaN in "output/input" array. Also i need to display the top column of "200077670" array like "2000776729".
05-06-2012 10:56 PM
When you divide a 0 by 0 it will give you NaN. Check the values coming in the denominator is a non-zero value since you are trying to calculate percentage (I Guess).
Good Luck.
05-07-2012 01:26 AM
Some of my denominator has values. Is it possible to display it in "0" instead of NaN for both non values and with values?
05-07-2012 02:03 AM
05-07-2012 03:39 AM
something like this?? not very good in this...new to LV
05-07-2012 03:53 AM
I use this to remove NaN from my arrays, hope this helps.
Epictetus
05-07-2012 04:08 AM
Thanks that was good but i am required to show the "0" array instead of removing it
05-07-2012 04:13 AM - edited 05-07-2012 04:17 AM
well then just replace the "delete from array" primitive with a "replace array subset primitive" or better with an inplace structure.
Epictetus
05-07-2012 04:31 AM
I generally use the following method. 1st one replace the NaN with 0 and the 2nd removes the NaN.
Good Luck.
05-07-2012 04:32 AM
you'd be slower on large arrays 😛
Epictetus
