08-31-2009 12:35 AM
Let me first explain my problem,
I have a data acquisition card, taking input at 22050 samples/sec.
But after every 9300 samples or 488 msec (approx.)(see attachment) some noise is coming, i.e. in 1 sec (22050 sam) the noise repeats itself twice.
I think the problem is with hardware, that we trying to sort out.
but i have given the job to solve it with software.
With help of signal generator, i have given 100mV, 100Hz sine wave input, that i have recorded as wav file.
By reading the wav file you can see the signal and noise seperately, respective VI is attached.
Is there a method to remove it.
08-31-2009 12:56 AM
08-31-2009 01:01 AM
Hi MUKS,
Thanks for quick reply,
The cable length is small , about 15 cm, then also i will try to shorten it.
08-31-2009 01:13 AM
Hi again,
I am connecting the card through the USB port, so i tried by connecting the card directly through USB port, then also the noise exists.
sound nt
08-31-2009 03:34 AM
08-31-2009 04:58 AM
I didnt do much, just used the VI given in the Examples. (Sound input to file).
But i have some other programs which detect the card and take input then also the noise comes.
Cant there be any method to eleminate the noise.
08-31-2009 05:57 AM
08-31-2009 06:11 AM
08-31-2009 06:34 AM
08-31-2009 06:46 AM
You can try the modifications I have made. I used constants just to show the value. The Labview sound system may create errors then reading data more than once every second.
