Removing floating subdiagram label
After some rework on the VIs to eliminate un-needed sequences I noticed a problem with subdiagram label...
As you can see there are at least two residual label floating around... and they cannot be removed in any way (for my limited LabView knowledge).
They cannot be 'selected'
I tried also removing the container sequence but the label persist... I can only change the text inside (of course they are empty).
How can I fix this?
Message 1 of 19
(419 Views)
Hi Michele,
Get an older version of that VI from your SCC repository and start to "rework" again. Try to avoid the steps that created those floating labels...
What did you do to create them?
Whenever I reworked older VIs I mostly remove sequences at all so there is no need for sequence frame sublabels...
Message 2 of 19
(415 Views)
Hi Michele,
Can you attach your VI (pref version LV2021)?
I could try inspecting the VI with VI scripting.
Raphaël.
Message 3 of 19
(413 Views)
I can attach it without problem but LV2013.
Message 4 of 19
(382 Views)
hi GerdW... unluckly the original code was already populated with sequences and sublabels.
Message 5 of 19
(381 Views)
If you activate warnings in the Error window (ctrl+L) is might show floating labels and you can select them from the list.
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 19
(374 Views)
Hi Michele,
This is not the main problem with your VI!
(Using SCC would help when those floating labels are created by your attempts to improve this VI.)
You should create subVIs from main steps and recreate the main VI from scratch using those subVIs and a better architecture.
In a proper architecture there should be NO Stop function inside the VI, but right now there are dozens...
@Yamaeda:
This only helps when there are no other errors. Right now the error list shows a max of 100 errors due to all those missing subVIs and global variables...
Message 7 of 19
(360 Views)
I opened the vi in LabVIEW 2017. I managed to vertically resize (shrink) both labels until they disappeared.
Paolo
Message 8 of 19
(355 Views)
How did you do? I can focus these sublabels but I cannot select them neither pin on an edge to resize it...
Message 9 of 19
(339 Views)
Moving carefully the mouse pointer near the horizontal center of the label I eventually saw the resizing blue squarelet.
Paolo
Message 10 of 19
(333 Views)
