Removing "plus" symbol in Excel
Ok.. I can't test my VI now, but i just implementet the "scan from string" box in my VI
Best regards
Oesen
Message 21 of 30
(1,891 Views)
You completely missed what I was trying to explain...
Let's see if I can rewrite what you did and show you an example of what I tried to explain...
Message 22 of 30
(1,887 Views)
Here is a snippet of what I meant:
Message 23 of 30
(1,884 Views)
I have tried your solution, and thanks for the help, but the array doesnt show any decimal number in the measurement part ?. I want two decimal numbers, how to do that ?
Best regards
Oesen
Message 24 of 30
(1,868 Views)
I'm not sure what you mean because it should work with decimals. See image below:
And it works even if there are no spaces:
+35.24g
will give
35.24
Message 25 of 30
(1,863 Views)
Hi Oesen,
did you read the context help as recommended?
Did you try the format string "%s%.;%f" after reading the context help carefully?
Message 26 of 30
(1,854 Views)
Hi Gerd,
Did I miss something?  Why "%s%.;%f"?
Does the OP want to conserve the + sign and save it into the spreadsheet?
If so, then using the indicator to export to the spreadsheet file may not do what the OP wants.
I must be missing something...  😞
Message 27 of 30
(1,849 Views)
Hi Ray,
the OP said (s)he was missing "decimal numbers" (fractional part of the number). So I guess the computer the VI is running on is using a different decimal separator and thus included "%.;" in the format string to assure proper conversion of the value in the device string...
Message 28 of 30
(1,847 Views)
Ah...  I didn't think of that one.
Thanks!
Message 29 of 30
(1,845 Views)
Thanks for the help guys. I wrote '%.;%f' in the format string box, and everything works fine now 🙂
Best regards
Oesen
Message 30 of 30
(1,834 Views)
