11-19-2019 10:40 AM
I'm trying to resize the chart to fit in a tab control that is already resizing to fit a window. Problem is, I can resize the black square, I can move the legend, I can position the Chart "gray box"
I end up with:
How can I size the main box?
11-19-2019 10:48 AM
Try positioning your mouse where I put a red circle to resize the entire chart:
11-19-2019 10:55 AM
Sorry, programmatically
11-19-2019 11:33 AM
Your picture has too poor resolution to read.
You should be able to use the Plot Area:Size property to resize the entire chart.
11-19-2019 11:44 AM
If you click the picture and then full screen it you can see it very well. I am using that property though. Perhaps it's the order in which I'm applying them.
11-19-2019 11:47 AM
Eliminating the PlotBounds property in the middle seems to have fixed it.
11-19-2019 11:48 AM
Even if I open in a separate tab it's a very blurry 400 x 124 px image. Can you upload the actual VI?
11-19-2019 11:49 AM
Ok good to hear!
