Resources for LabVIEW best practices
Hi there,
I'm working with LabVIEW for the first time in a long time. We'll be building a small-medium sized application:
  • ~a dozen relays and actuators
  • ~a dozen sensors
  • logic to control the actuators based on the sensor readings, timing and process stage
  • recording data to disc throughout the process
  • the process is not particularly high speed, so a system tick of 1s or 5s would be OK.
Before I dive in and start making a complicated mess I'd like to get up to speed on best practices for structuring this kind of project in LabVIEW. Can you recommend a couple of short articles or blog posts that would help me avoid the most common mistakes?
Tom
(926 Views)
What device you will be using to interface with the sensors and actuators? NI-DAQmx devices? The choice of hardware and driver API sometimes provide some built-in feature that can simplify the programming.
If it is just for the LabVIEW design pattern, State Machines and Queued Message Handler are a good start.
(883 Views)
Thanks ZYOng - yes cDAQ for the most part, so hopefully that makes life as easy as possible.
Thanks for the links. I'm familiar with state machines and today I've read through a few of the message handler examples. The Continuous Measurement and Logging example looks the most relevant, and I think I have a good grasp of how it works. I'm planning to just build off this example project - I think my first step will be to extend the data queue so it uses a custom data type, and make sure I can successfully write/read that queue (I need to pass around several data streams, not just a single waveform).
Step 2 will be to integrate some of the hardware rather than using dummy data.
Tom
(862 Views)
I suggest reading this article to become familiar with some LabVIEW concepts that will likely prove useful as you work on your application.
Design Considerations in LabVIEW
(839 Views)
