Right Click Menu Items
I know this is VERY simple, however, I can't figure it out.
I'm trying to re-create this Application from scratch.
How are the Right-click menu items created?
HELP
Keith
(509 Views)
To edit, make sure you right-click the very edge of the array, then select Advanced -> Run-Time Shortcut Menu-> Edit:
To activate anything you add to the menu, create an event structure, then create a case for the array, then the shortcut menu, then the appropriate sub-event:
"App" is for anything built-in.  The one with the question mark allows you to cancel the built-in functionality.
"User" would be for anything you add to the menu manually.
(472 Views)
Kyle, thanks for the suggestions, however, I couldn't get to the "Insert Element Before" and "Delete Element" from the right-click menu while the application is running.
Can you please help me create another Array with another right-click menu with any items?
Keith
(455 Views)
Keith
If you need the only these, then you don't need to customize menu, this is how it looks by default in run-time:
Be sure that the defaukt menu is enabled in VI props:
But if you prefer to override default with your own customized, then you should use these two tags:
APP_SC_DELETE_ELEMENT
APP_SC_INSERT_ELEMENT_BEFORE
(410 Views)
THANKS !!!
That was the solution
Keith
(394 Views)
