Ring Control Default Value
I have  a ring control which is having  a default value of <10200>.
I cannot replace this with a new ring control as i am using a lot of its property nodes in different cases.
How can I remove the default value..?
I have attached the control for reference.
(4,020 Views)
Accepted by Flamboyant
You cannot remove a default value. You can only set a new, different default value.
Norbert
Norbert
Expert: Geometry
(4,019 Views)
How to set new different default value? Help me. Thanks.
(3,559 Views)
Enter a new value.  Right click  Data Operations >> Make Current Value Default.
(3,540 Views)
(3,522 Views)
