Rotate 1D Array continuously
Hello
I am generating Sine Wave and sampling it at 12 samples/ Cycle and storing it in the array. I want to rotate this array continuously one sample at a   time. Suppose my array is [20 10 5 3 1],  I want this array as [1 20 10 5 3] (the last element become the first element)next time I want this array as [3 1 20 10 5 ].
Any Suggestions.
Sugandh
(4,383 Views)
You can use the 'Rotate 1D Array' VI in the Array palette.
Smiley Happy
(4,376 Views)
By Using 'Rotate1D Array' Array rotated one time only. I want to rotate 12 times. Or continuously.
Any suggestions
(4,369 Views)
Accepted by Sugandh
(4,362 Views)
Sorry, I didn't check out your VI before suggesting the Rotate 1D vi.
The above code should rotate the array once per loop.
(4,358 Views)
You can connect the Waveform Graph to the output of the Rotate VI to view the sine wave changing phase. Smiley Wink
(4,356 Views)
Accepted by Sugandh
It would be more universal if you would rotate based on the array size. This way you don't need to change constants and cases whenever the requirements change.
(Insert a "Negate" on the blue wire before the "rotate array" node to rotate the other direction)
Of course the "simulate" should be before the loop because the output is constant.
(4,312 Views)
