Rotating a 3d object with euler angles
I'm trying to creat a graphic represantation of a 3d object whose attitude is given as euler angles (yaw, pitch, roll), and I'm having troubles rotating it correctly. I've been fighting with this thing for a couple of hours but I guess I'm just missing something
I would love any help in getting this thing working. (is there a straight forward way of rotating an object around it's own axes?)
Thanks a lot!
(4,556 Views)
  • When attaching more than one VI, tell us the name of the toplevel VI.
  • Why do you think you need to run the loop as fas as the computer allows, rotating the y axis with every iteration?
  • In newer versions of LabVIEW, there are all needed tools for euler rotations in the geometry palette (not sure if that was available in LabVIEw 2009).
(4,544 Views)
Thank you for your comment!
- You're right, I'm sorry- "display orientation" is the main VI (well, I guess you figured it out but for future readers)
- Right again- just forgot to add a wait function.
- I'm actually working with  LV 2013, just saved for older version because I know some of the readers can't view it otherwise. I know how to rotate axes, but I can't get the "rotate object" VI to work as I want. I never seem to get what axes it turns the object around
(4,512 Views)
Accepted by shayelk
Sorry, I don't have access to LabVIEW at the moment, but if I remember right, there was a problem with the rotation in some older versions. Instead of "rotate", use "set rotation", If I remember correctly. I'll have to look at my old code.
(4,501 Views)
Thank you altenbach! That actually did the trick 🙂
my code is attached in case anyone'll stumble across this thread ("display orientation" is the main VI)
(4,494 Views)
Wow! Thanks! simplified a lot and was a great help actually!
(4,154 Views)
