Rotation Controller with SGSP-60YAW-0B
I have this controller "SGSP-60YAW-0B", I would like to design a LabVIEW controller for this motor.
I am still a beginner in LabVIEW. Do you have any ideas or suggestions! what shall I do? If anyone uses this kind of instrument could help.
Message 1 of 18
(2,875 Views)
Hi BaJa,
The linked website lists several compatible drivers/controllers: why don't you use them?
Then hurry up to take the online courses offered for free until end of April!
Message 2 of 18
(2,861 Views)
I dont use the ready drivers or controller because this controller is only one of many instruments that I want to design code  for them,
about the course, can you send me the link, please!
Message 3 of 18
(2,858 Views)
Hi BaJa,
Do you notice that orange/red button right on NI's homepage?
Message 4 of 18
(2,844 Views)
We have your products ""SCSP20-85 & SGSP-60YAW-0B"".
It's working fine with the attached LabVIEW controller.
This controller can control the movement, speed, and stage origin position.
But how can I show the stage position! which function or controller should I use to show the stage position!!
If anyone knows about this controller, please guide us.
Message 5 of 18
(2,829 Views)
Hi BaJa,
Have you read the (programming) manual? Did you learn about all (relevant) commands and responses of this motion controller?
I'm sure there is a command to request the current position…
Which motor controller do you use? Can you provide its name/type and a link to its manual?
Message 6 of 18
(2,787 Views)
There is no programming manual available on the company website or anywhere else online.
I have contact with them about that, they send me the attached catalogs.
and this website for LabVIEW examples.
https://www.global-optosigma.com/en_jp/software/sample_en.html
It doesn't contain any commands to showing the current position.
or maybe I don't find the requested commands.
Message 7 of 18
(2,779 Views)
Hi BaJa,
the example VIs are made for RS232/GPIB communication. The specs you show don't provide any serial or GPIB communication ports: which device translates between your computer and those stages from RS232/GPIB to analog/digital signals for those stages?
Please provide as much information as possible!
In those VIs commands like "R", "G", or "M" are used: you need to get a manual which describes all those commands, their options and responses!!!
(Btw. those examples are written in a really bad way using a very old version of LabVIEW: you really should recreate them from scratch using modern style and guidelines…)
Message 8 of 18
(2,772 Views)
the attached library has been modified according to my system.
As I mentioned, it already works fine. my LV version is 2018 (64).
please check.
But I didn't have any guidelines for this controller.
Message 9 of 18
(2,761 Views)
Hi BaJa,
But I didn't have any guidelines for this Controller.
Simple answer: No manual, no help…
I cannot open your LV2018 VIs, please downconvert to LV2017…
Message 10 of 18
(2,742 Views)
