Routing of counter output
Using LabVIEW 2009,  I'd like to route the output of ctr0 to several PFIs. I've reviewed many of the posts, but I'm still a little confused on how to route to multiple outputs.
It seems there are three possibilities - DAQmx Connect Terminals, DAQmx Export Signal, and DAQmx Channel property node.
Is it possible to route a ctr0 pulse to multiple outputs? If so, which of these options is best? (I assume I would make multiple calls to the Connect Terminals or Export Signal) Is there a limit to the # of outputs I can drive with a ctr0 signal?
Thanks.
(3,273 Views)
Accepted by rls9642
Hi rls,
The easiest way to accomplish this is to use the DAQmx Export Signal VI.  You can route the signal to multiple routes by selecting to Browse... rather than selecting a single PFI line and then CTRL+Click on the routes to be made.  I was able to do this on a PCI 6251 M-series multifunction card without any issues.
Best,
Adam
Academic Product Manager
National Intruments
(3,242 Views)
Thanks for the assistance.
(3,236 Views)
Worked for me on a PXIe-6341 X-series device !!. Perfect solution, thanks!!
(It was difficult to find the solution).
(2,880 Views)
