Running a 3rd Party Program
All,
I want to be able to launch and run a 3rd party program via LabView.
Launching the program via "System Exe.vi" is simple enough.
But now I want to programatically make all the button pushes. So instead of the user having to navigate the 3rd Party GUI, it would be done via Labview.
It sounds like I would need a dll and know the entry points but if I only had the exe is it still possible?
thanks
(3,559 Views)
If you know the keyboard shortcuts, you could try using send keys:
http://forums.ni.com/t5/LabVIEW/Anybody-knows-how-to-do-send-key-function/td-p/348011
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(3,556 Views)
I've use Autoit in the past for this.
(3,551 Views)
I tried the Autoit and like it. This may do the trick.
Are there any other ways to accomplish this same task?
thanks
(3,510 Views)
Accepted by CarmineS
Another option would be to use windows or user32 dlls to generate mouse clicks. But if the executable file isn't desinged for access promaticaly, it will be a harder task to accomplish. You can also follow below link for more help.
http://digital.ni.com/public.nsf/allkb/CA411647F224787B86256DD000669EFE
Applications Engineer
(3,473 Views)
Can user32 be used to acquire a list of windows on the screen, select the application window and then obtain controls and indicators for populating and pressing? It seems like a form type of dll is probably what I'm looking for.
(3,348 Views)
For LabVIEW front panels, NO.
You can't get a list of controls or indicators with user32.dll.
Since LabVIEW objects aren't window objects.
George Zou
(3,341 Views)
