Running a Tensorflow model in NI Vision Dev. Module 2018
I am trying to test a signal processing model trained with Tensorflow using the Deep Learning from NI Vision Development Module 2018. I loaded the model with IMAQ DL Model Create function and now I want to use it with an array dataset with IMAQ DL Model Run, but I do not succeed to find the “Output Model Names” of the model required by the function. I tried to find it with model,input in Tensorflow, but the item it returns does not fit the Labview function. Can anybody help me? Thank you.
(1,481 Views)
Accepted by cfosalau
Firstly, you need to to freeze your model weights in .pb format as described here
To get the model input output names, run the following commands after you define the model:
print('inputs: ', [input.op.name for input in model.inputs])
print('outputs: ', [output.op.name for output in model.outputs])
PS. I use above commands when defining my model in Keras.
(1,455 Views)
great! It works! Thank you very much, BeeRio.
(1,431 Views)
Glad it worked. You can mark that as solution.
Thanks.
(1,418 Views)
