08-27-2009 11:19 AM
I would like to control relays to turn a heat tape on and off which requires 3-30V input. Is this possible with the SCXI-1163 Digital Output? I have a SCXI-1326 module for it. Would a wire be connected to the VCC or the Ground to get the 5 V across the channel?
Thank you,
Dustin
08-28-2009 05:24 PM
Hi Dustin,
As long as your relays conform to TTL standards this device should work well. Also, you should be able to drive the 5V line directly from the channel line.
SCXI-1163 User Manual and Specifications
Glenn
