SMC100 LabVIEW Drivers are seen as "Question Marks"
Dear all,
I am trying to install the SMC100 device drivers
The SMC100 controller drivers has been developed under LABVIEW 6.1.
So i installed also LABVIEW 6.1. run time engine.
I installed the drivers(in the link below) to the  "instr.lib" file as required.
ftp://download.newport.com/MotionControl/Current/MotionControllers/SMC100/Software/
When i open the block diagram(functions pallette), the SMC100 drivers are seen as question mark like in the attached picture.
I am using Win7 32 BIT, LabVIEW 2009, and also
*My device still on the way from USA to Turkey, so i did not connect the SMC100 device to my PC yet. Is it smthg to do with this? Should i connect the device to install the drivers?
(3,291 Views)
It should not be necessary to have the device to install the instrument driver. I have instrument drivers installed on my desktop development PC and I have no instruments connected.
Hopefully others can shed some light on how to fix the problem you are seeing.
(3,274 Views)
Accepted by Kindly-Wisher
Try mass compiling the folder with the drivers.  If the drivers were downloaded without the block diagrams, then you will not be able to compile them because the source code is missing.
Lynn
(3,272 Views)
I don't know how you managed to install the driver so that the palette is a top level one but it appears to be in an incorrect location. Post an image that shows windows explorer and instr.lib and where you have the driver.
(3,267 Views)
Dear  ,  , and nyc
(3,255 Views)
