Sampling on Ethernet CompactRIO Chassis
I'm using NI 9147 Chassis RIO with NI 9215 Analog Module.
Device configured for RT Scan mode and in scan engine properties scan period set for 1 ms.
My question is,
1. where to configure sampling rate setting for NI9215.
2. Scan engine properties, scan period set for 1 ms. Does it mean maximum sampling rate 1000s/S.
3. Can i get from NI9215 100 kS/s/ch, 16-Bit, Simultaneous with this setup.
I'm totally confused, someone please help me on this.
Message 1 of 9
(1,349 Views)
Hi electronbas,
@electronbas wrote:
My question is,
2. Yes, you will get (at most) 1kS/s with a scan period of 1ms.
3. No, you will not be able to read 100kS/s from your module when the ScanEngine only reads new (single!) samples each 1ms…
Message 2 of 9
(1,345 Views)
Hello GerdW,
Thanks for your quick response.
Now i understood from your answer that Ethernet Compact RIO Chassis can sample 1 kS/s irrespective of IO module specification.
 Is your answer applicable for both RT scan mode and as well as FPGA programming on Ethernet Compact RIO Chassis?
Would you recommend cDAQ for NI9215 for achieving full sampling rate?
Message 3 of 9
(1,328 Views)
A single slot cDAQ would be the simplest route.  DAQmx does all of the work for you.  If you want Ethernet, then the cDAQ-9181 should do the job for you.
GCentral
Message 4 of 9
(1,311 Views)
Accepted by electronbas
Hi electronbas,
You understood wrong!
Even when you set the ScanEngine to read samples at 1kS/s it cannot read faster than the IO modules allow! There are several modules with samplerates of less than 100S/s…
To rephrase the sentence: you can read new samples with a samplerate of minimum(ScanEngine samplerate, module samplerate)!
You explicitely asked for ScanEngine usage, so my answer only applies to ScanEngine mode!
Using FPGA you can utilize the full samplerate of your IO modules…
As said before (by @crossrulz): using a single slot (USB?) cDAQ would allow for most simple DAQmx implementation of your NI9215 readings…
Message 5 of 9
(1,303 Views)
Hi
@Crossrulz thanks for your recommendation.
@GerdW thanks for your explanation and made me to understood.
NI9147 Ethernet Compact RIO Chassis, can be used for higher sampling >1kS.
If yes, how can i proceed?
Message 6 of 9
(1,254 Views)
Hi electronbas,
Use the FPGA examples for your modules to learn how to implement support for high samplerates (as high as supported by your modules).
Then implement FPGA code for your cRIO chassis.
(The ScanEngine is quite limited in its features/abilities.)
Use the (cRIO) example projects to learn how to transfer your "high speed" data to your computer. I recommend NetworkStreams…
Message 7 of 9
(1,247 Views)
Hi GerdW,
Thanks for your time and support.
Message 8 of 9
(1,231 Views)
NI-9147 has no controller and hence cannot use network stream.
You use DMA FIFO to stream data from FPGA to the host. You can find some examples at Help >> Find Examples... >> Hardware Input and Output >> compactRIO >> Fundamentals >> Data Transfer and Storage >> FPGA to Host >> Streaming Data (DMA) or Interleaving Channel Data (DMA)
Message 9 of 9
(1,217 Views)
