Scaling one channel while reading multiple channels
Hi everyone, I am currently trying to read two sensors (strain gauge and displacement sensor) on two channels. However, I want to do some scaling only to the strain gauge (V -> N) and not to the displacement sensor. Does anyone know how to tackle this problem? My approach can be seen below, but this scales both channels...
Thank you for any help!
(473 Views)
Accepted by crossrulz
Hi User207,
Create one virtual channel with scaling applied to your DAQmx task. Then add another channel (without scaling) to the same task!
You just need two DAQmxCreateChannel calls…
(466 Views)
Great, it works!
Thank you GerdW.
Appreciate your answer!
(449 Views)
To show your appreciation, go back to Gerd's answer and click the "Accept as Solution" button (it was your question, so you get to decide if one or more Replies solve your problem).  This helps the next person who has a similar question "find the Solution" faster, and gives Gerd a "warm feeling" for sharing his wisdom and LabVIEW experience.
(421 Views)
