Scan from String Error 85 does not recognize value as string
I'm following this example to separate what's before the dot and after in a string:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YPlUCAW&l=en-US
I've tried to adapt it here, it works halfway, Labview separates decimal "7" before the dot and string "X34" after the dot. However, when I change my mask to "%s.%s", I expect to see string "7" and a string "X34", but I get error 85, "Scan failed. The input string does not contain data in the expected format". It doesn't seem to matter if I replace "7" with a string "ABC", I still get this error. I'm so curious why does this code works halfway?
(1,016 Views)
Accepted by John32d
The problem is that the first %s is grabbing everything and then there's nothing left for the '.' and second %s. Scan from string is a greedy operation. You'd be better off splitting off the '.' explicitly (if you're not expecting decimal values at all) with match pattern and a pattern string of '\.' and then you can take the before and after inputs.
~ Self-professed LabVIEW wizard ~
Helping pave the path to long-term living and thriving in space.
(1,010 Views)
Obviously, it cannot tell where one string ends and the next begins. One possibility:
(1,003 Views)
This solution kind of works, but it splits the string when it sees the first dot. Is there a way for it to split on the last dot?
(966 Views)
You need to use pattern matching or even regex. LabVIEW is not clairvoyant!
(960 Views)
You can do a match pattern telling it to grab a '.' and everything up to the end of the string that isn't a '.'. If it finds a second '.' it restarts the match there and keeps grabbing characters until it hits the end or finds another '.'. The pattern is \.[~\.]*$ and follows normal regex patterns you'd see for PCRE format except that within the [] the ~ is there instead of ^ in PCRE. If you use something like regex101.com you'll see the explanation using a ^ instead of ~ https://regex101.com/r/QXWxIr/1
(919 Views)
Thank you, reversing the string and using matching pattern so it grabs the last entry only worked for me.
(834 Views)
