04-24-2014 01:57 PM - edited 04-24-2014 01:58 PM
Hello guys,
Could someone take a look at my code and suggest things that could make it faster? I am bringing in a rather large 2D array (~85000x71) and I am extracting two columns from the array & doing some comparisons against. There are 4 files total each broken out in 6 hour increments. One of the files is provided in CSV format. I feel like there is room for improvement. Could someone take a look and suggest alternatives that may be faster?
Eric
04-24-2014 02:51 PM
I'd just autoindex over the full array and do all comparsons at once. You can wire strings directly to a case structure and make one case "0" and the other the default.
Instead of "insert into array" of two adjacent columns, you could just use "array subset instead.
04-24-2014 03:22 PM - edited 04-24-2014 03:22 PM
I would probably do something like this. Since each loop is doing the exact same thing, you might as well just make it a subVI so that you only have to edit it in one place. Be sure to set the VI Properties to execute as a reentrant VI.
04-24-2014 03:38 PM - edited 04-24-2014 03:38 PM
Here's a quick draft. It seems abour 10x faster (with 10% of your code, see my sig :D) than yours (same result). Modify as needed.
(This is not optimized for speed yet).
04-24-2014 03:52 PM - edited 04-24-2014 03:59 PM
Note that you can parallelize my FOR loop. (mine drops down to <2ms on my 16(32) core Xeon :D).
04-24-2014 06:54 PM - edited 04-24-2014 07:04 PM
oh darn!
the postage stamp version is coming! I love it when I learn something.
04-25-2014 07:06 AM
I used your example in the first sub VI and crossrulz example for similar code for comparing 0s in the first array and 1s in the second array in another SubVI.
Thnaks everyone again for your help.
Eric
04-25-2014 07:14 AM
Wait a minute. I thought you couldn't parallize a FOR loop that used shift registers. When did that get fixed? And now I'm wondering how it is working behind the scenes. Something to go play with now. Yep, not going to get any work done now. Good thing it's Friday.
04-25-2014 08:19 AM - edited 04-25-2014 08:40 AM
Certain code patterns are recognized as safe to parallelize. This is one of them. (else you'd get a broken arrow). Addition is commutative, so summing in a shift register does not depend on the order of the operations.
I don't know if there is a comprehensive list of such patterns. (some are listed here, look at figure 5, for example)
I even downconverted and tested in 2012 to make sure it still works. 😉
04-25-2014 08:31 AM
