Selecting/ Unselecting Curves from Labview Charts
Dear community members,
I have a question about labview charts. I have a chart looks like the attached image. It has multiple curve/lines(Red and Orange). I want labview to keep both of the data curve on the chart. But in some point of experiment, I want to unselect one of the data curves and focus on the other curve. For example, I want to unselect the red data curve during data collection and see the orange data curve only in the chart. Then I want to select the red data curve again and observe both of the data curve in the chart. Does labview have this feature?
Thank you.
(793 Views)
If you want to just hide the plot, enable the visibility checkbox.
If you want to create gaps where only one trace shows, feed the other plot with NaN.
(788 Views)
Accepted by topic author Jarir
Right Click on the Chart >> Visible Item >> check Plot Legend.
On the plot legend, right-click on the legend >> uncheck Plot Visible.
(786 Views)
Perfect! Thank you for making my life easy.
(768 Views)
Alternatively, you can right click and turn on the Plot Visibility Checkbox:
which gives you this little box to check/uncheck individual plots, which saves a couple clicks and is a little more intuitive for end users:
(745 Views)
