09-12-2012 07:55 AM
I don't know why all three displays show always the same image. Try with any three images, and you'll see that.
09-12-2012 07:59 AM
EvenDeejay,
I can't open your file - access violation.
09-12-2012 08:03 AM
Hi again,
I think I missed the functionality you were looking for. So, nevermind my VI.
09-12-2012 08:03 AM
What LabVIEW version are you using?
09-12-2012 08:05 AM
I am using LabView 2011.
09-12-2012 08:07 AM
Here's for LV2010. You should be able to open it. If not, It's probably because I don't have IMAQ.
09-12-2012 08:10 AM
Hmm. Seem's to something wrong here. Anyways, here's a picture:
Seems to be something wrong with the forum today. I can't use Opera to reply posts.
09-12-2012 08:10 AM
Still cannot open it.
09-12-2012 08:13 AM
OK, I found an error. I used the same 'Image Name' with every IMAQ... that's the way it goes when you use copy&paste... OK , now my code works great. Problem solved 🙂 Thanks for your time and help.
09-13-2012 03:14 AM
If you found the solution, could you mark this topic as closed?
Peter
