08-18-2008 05:43 AM
I can't access my MySQL database directly (GoDaddy ;-(( ) so I need to send the data through a PHP script. Has anyone done this yet? I have several ideas on how to accomplish this, but nothing seems efficient.
Any Ideas?
TIA,
Jim
LV7.1
LV8.0
08-18-2008 05:48 AM
Hi Jim,
what are your ideas? You can use the webbrowser activex component to load the page and fill out the elements.
Hope it helps.
Mike
08-18-2008 08:15 AM
Soooo... my idea was to use a Data Socket and write the values as part of the URL, but I don't know exactly how it is accomplished. I can read from a PHP page using this method to query data and this works quite well. I am doing more research and have found some good info.
Which way is better Data Socket or Browser Object?
Jim
08-18-2008 09:36 AM
Hi Jim,
if you can send your data as part of the URL, then i think it´s easier as using the Browser object.
Mike
08-18-2008 01:32 PM
Well...I got it to work as a URL multiple variable. It seems like a crude way to send data and I can only insert one row at a time, but WTH -- it works ;-))
Thanks for your help!!
Jim
