Send SMTP email on Labview Community 2023 MacOS
I have an issue in using the send email function that I need for my project. I'm using LabVIEW community 2023 on macOS. The simple vi in photo returns me this error and i couldn't find any appropriate solution on the other posts on the forum. I am using outlook and smtp2go in order to avoid any problem related to privacy settings.
Error -1967362015 occurred at LabVIEWSMTPClient.lvlib:Open Handle.vi:1020001
OS and Network Services: (Hex 0x8ABC7021) Failed to load library.
Complete call chain:
Untitled 1
Is it possible to solve the problem? Are there any ways to work around the issue by using any other function to send a notification to my phone? Thank you to anyone that is going to reply.
(113 Views)
I can verify that Send SMTP Mail works fine in LabVIEW 2021 (32-bit) and earlier versions running on PCs.  I have no experience running LabVIEW on MACs, and also have no experience with any version of LabVIEW Community for MacOS.  I also haven't tried later versions of LabVIEW, nor 64-bit LabVIEW (any version).
(101 Views)
Accepted by labnario
Hi, I solved the issue by using system exec.vi and giving the command to the macOS terminal using msmtp. You can install msmtp by terminal using “sudo install msmtp”. Best wishes
(57 Views)
