Set enum values through vi server
wiebe@CARYA,
Your method works, I have selected it as solution. Thanks for your help.
Message 11 of 16
(1,203 Views)
@Ben wrote:
@Yamaeda wrote:
If you mix enums you need to use the numerical representation instead.
/Y
That example is just ONE of the newer features available in modern versions of LabVIEW that I alluded too.
Those functions can be found on a variant sub-palette.
Just like working in a machine shop, it is a good idea to get an idea about ALL of the tools in in your tool-box otherwise you will find yourself trying to drive a screw with a hammer.
But in fairness to my old nugget, back then we only had hammers and screwdrivers had not yet been invented. (smiley-wink).
Ben
Once you start swinging the hammer, its hard to stop viewing everything as a nail.
Message 12 of 16
(1,192 Views)
Ben
I thought you only had rocks and sticks back then. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 16
(1,168 Views)
Ben
/Y
Rocks and sticks and no undo! Someone should get lv2 working in a VM...
Message 14 of 16
(1,161 Views)
@Yamaeda wrote:
Ben
/Y
No, we also had bearskins.
Spoiler
I HOPE this is the correct un-adulterated video!
Ben
Message 15 of 16
(1,153 Views)
It actually seems feasible.
Lv3 is available here...
Message 16 of 16
(1,148 Views)
