Signal to controller to enable motor, periodic within periodic duty cycle
Hi Gerd,
I did get a case structure working based on 2 states (enable and dwell) using 1/4 sec wait and counting down itterations.  I've been busy elsewhere which is why I'm only now getting back here.
I'm having difficulty implementing a temperature limit which will stop the entire while loop. I tried doing this outside the case structure as well as inside the case structure.
One issue is that I have a 1D array of booleans after comparison with temp limit.  The stop loop condition does not accept the array.  A select function does not accept the array either.  Max Min function also outputs an array or waveform.  How do I check if any value within the array exceeds the limit and then send a single boolean out?
I thought about your suggestion (like: IF counter>0 AND "temp limit not reached" THEN continue heating) but I don't see how to select the "End Test" state.  I can only select between 2 states with the select function which are now enable and dwell.  The temperature comparison should not be used as a thermostat but rather an interrupt.
IF counter>0 AND temp<limit THEN select enable
IF counter=0 AND temp<limit THEN select dwell
IF counter>0 AND temp>limit THEN ??? I can only select between 2 right?
vielen Dank und sonnige Grüsse
Message 11 of 11
(160 Views)
