Simultaneous analog acquisition and generation of one TTL pulse
Hi
I need to acquire 1 s of analog data. 100 ms after the start of the acquisition, I would like to send one TTL pulse (digital output) to start an other device.
I'm using LabVIEW 2011 and could not find an appropriate simple example.
Thanks a lot for your help.
Anne
(2,763 Views)
Everything depends on the hardware you are using. So what device are we talking about?
Christian
(2,759 Views)
How precise does the 100msec need to be?
Mike....
Certified LabVIEW Architect
LabVIEW Champion
(2,757 Views)
Hi Christian
I'm using a PCI 6071E.
Anne
(2,743 Views)
Hi Mike
around 1 ms is fine.
Anne
(2,742 Views)
Have a look at the example "Gen Dig Pulse-Dig Start.vi". Use this example in combination with your Analog Acquisition Task to fire the pulse.
Use the "Initial Delay" parameter to specify the 100ms.
As Trigger Source use "DevX/ai/StartTrigger", where X is your Device, e.g. Dev1.
Christian
(2,684 Views)
