Small UI pipes pixel
While I can't get smaller than 5 pixels either, I have another idea that might work (and that might actually be thinner than the 5-pixel String Indicator).  Use a Classic Boolean Box Indicator (which, by default, is a 20 by 20 square).  Name it, make the Label "not visible", and (I recommend) create a Property Node and programmatically set the Color, BtnSize, and Position properties.  If you make the Foreground color "transparent", the "pipe size" will decrease by 2 pixels.  In the example here, I've used only one Color, so changing the value of the Boolean won't change the Pipe color, but if you wire in two colors, you could programmatically change the Boolean and have that pipe "blink" to draw attention to itself.
This, of course, only draws horizontal and vertical pipes -- to make pipes with bends, you'd have to create an array of these things and adjust size and position appropriately, but all of that could be handled by a clever VI, allowing you to treat the entire Array (which could have a single element if there was just a straight pipe) with settable properties being Position and Color.Pipes.png
Message 11 of 15
(1,368 Views)
Accepted by RavensFan
I was about to edit my Reply, but saw that two people had already viewed it, so I'm adding a followup.  It turns out (when I took a picture of it) that my 5-pixel Pipe with a transparent border is actually 3 pixels (the border apparently "counts" in the width).  Furthermore, you can add the "blinking" property (seen in the revised snippet) and get the Indicator to handle "calling attention to itself" for you.  Here is the revised Snippet and the resulting Pipe -- the "blink" variety is Red, with a 1-pixel yellow border (so it is, in fact, 5 pixels).
Message 12 of 15
(1,360 Views)
My goal was 2 pixels but 3 is way better than 5.  Good Idea. Thanks.
Message 13 of 15
(1,349 Views)
Message 14 of 15
(1,339 Views)
Now thats a cool pipe.  If I go 3D and fancy I know where to go.  Thanks.
Message 15 of 15
(1,335 Views)
