10-10-2009 07:28 AM
Hi all,
I send et sine waveform to the speaker. If I change the frequency, the sound changes consequently however changin the amplitude dont changes the sound. how to do to change the sound amplitude. I need to process sounds with filters and amplifiers.
10-10-2009 08:49 AM
Blog for (mostly LabVIEW) programmers: Tips And Tricks
10-11-2009 09:38 AM
I need to controlthe frequency and the dB sent to the speaker. when changing frequency on VI, the sound changes. when changing amplitude no changes accures about what I hear:
10-11-2009 11:53 AM
neil84 wrote:I need to controlthe frequency and the dB sent to the speaker. when changing frequency on VI, the sound changes. when changing amplitude no changes accures about what I hear:
You can not control the dB level the way you are trying to do it. Take a look here for an introduction regarding dB http://www.phys.unsw.edu.au/jw/dB.html.
Also then using the a DBL as type for sound output. The wave is normalized to +/- 1 in amplitude. I will recommend that you do not use Express VIs. Study instead the Labview examples for sound output and input
10-11-2009 01:05 PM
I looked to the examples. there is some example where is possible to set volume. However there is no information about what sound level is sent.
My aim is to send a specific frequency and sound leve to the speaker ( W/m2).
Actually for simulation 'm doing this:
to convert dB to Acoustic level and I need to send this specific level to the speaker
10-11-2009 03:12 PM
neil84 wrote:Hi,
Please trust me on this one. There are no standardized formats regarding sound card and amplifier systems/speaker system output level. So you can not take a random system and have it to output a some standard sound output level in W/m2. The only way you can do this, is to calibrate your system with some sound level measurement equipment
10-17-2009 12:46 PM
