Sourcing current with Keithley 2450 and measuring voltage using NI 9239 DAQ
Hello guys, I am fairly new to LabVIEW and I am trying to write a LabView code where I have a Keithley 2450 that only sources current, and a NI 9239 DAQ will measure the voltage. The current problem I have is that I cannot find a way to do so. I have tried the code where the Keithley sources the current and measures it however the NI 9239 DAQ is unable to measure the voltage. Is there a better way to write the code in order to get my desired outcome? I have attached a picture of the code I am working on. I've tested the code and the Keithley device is able to act as a current source and measure it however the NI DAQ is unable to measure the voltage. Is there a way to just make the Keithley device Source the current repeatedly?
(1,049 Views)
Hi weazidaki,
@weazidaki wrote:
  1. however the NI 9239 DAQ is unable to measure the voltage.
  2. I have attached a picture of the code I am working on.
  3. I've tested the code and the Keithley device is able to act as a current source and measure it however the NI DAQ is unable to measure the voltage.
  1. Why is the DAQ device unable to measure a voltage?
  2. We cannot run/edit/debug images with LabVIEW...
  3. Again: what's the reason?
Have you tried to measure a known voltage, like from a simple AA battery, to verify the cabling?
(1,028 Views)
Thanks for the quick reply,
The current testing configuration has the force hi and force low cables connected to two ends of a 1k ohm resistor. The ai0+ and ai0- lines are connected to the inner portion of the ends of the resistor. I disconnected the Keithley device ad the NI DAQ was able to measure the voltage. However, when I reconnected the Keithley device and tried to run both of the devices at the same time, the NI DAQ showed random data. I uploaded the VI file that I am working on, sorry for not uploading it in the first place.
(1,015 Views)
Hi weazidaki,
Can you please attach a schematic of your cabling including both DAQ devices and the resistor?
What are "force" cables?
Which kind of "random" data?
(997 Views)
