Starting a Program
I would seriously consider creating a subVI for your processing. Every one of your rowsis being processed the same way. You could simplify your block diagram by using a subVI for your processing tasks and simply pass in the necessary parameters that are different. Also, as a general rule you want to keep your block diagram's size to be equal to or less than one screen size. You want to avoid scrolling your diagram in order to see everything. If it is too big for a single screen it generally means you need to look at the code and find pieces that can be made into subVIs.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 15
(758 Views)
Make a Subvi of all the information to be writen into strings. You really need to condence your program.
CLD Certified 2014
Message 12 of 15
(746 Views)
Should the Subvi have a while loop inside of it?
CLD Certified 2014
Message 13 of 15
(728 Views)
I think the program will not run correctly without the while loop inside the subvi.
Message 14 of 15
(726 Views)
Here is an example on how to find the time at max. I hope this helps.:smileyhappy:
CLD Certified 2014
Message 15 of 15
(712 Views)
