Status of CAPS LOCK
How do I detect the status of CAPS LOCK? Is it possible to control the status of CAPS LOCK?
(5,153 Views)
I am not sure about detecting/controling the CAPS LOCK, but if caps are giving you a problem there are ways around that. There is a "To Upper Case" function in the String function palette. Convert all user inputs to upper case and use all upper case comparisons. If this is not your problem, just disregard.
- tbob
Inventor of the WORM Global
(5,141 Views)
Use the GetKeyState function from user32.dll. It recieves a key number (Caps Lock should be 20) and returns a byte. The low order bit says whether the key is toggled.
___________________
Try to take over the world!
(5,119 Views)
Thank you. It works
(5,110 Views)
Thanks, its helped me so much
(672 Views)
Here
(624 Views)
