Storing 1D array in multiple columns using write to spreadsheet
Hi
I am getting 1D array and I am able to save in a single column using write to spreadsheet. However, I need to store this 1D array in multiple columns. For example if I am getting 1000 element in 1D array, I need to save 200 elements (user given number) in each column making total of 5 columns.
Further, can I use this new 2D array to plot intensity graph? Please help.
(3,080 Views)
Use Reshape Array and write it as a 2-D array to the "Write to Spreadsheet" subVI.
Sure, you can write it to an intensity graph.
(3,075 Views)
Thank you for your suggestion. I tried using reshape array and got 5 columns of 200 elements when I used an indicator but I could not write this to spreadsheet as well as to the intensity graph as it is giving error that I connected two arrays of different dimension. The output from the "Reshape array" has dimension 5 but the write spreadsheet and intensity graph can accept only 2.
Please help.
(3,068 Views)
You've done something wrong if you don't have a 2D array so show what you have done.
(3,061 Views)
Ok it look something like this. Here 30 elements in 1D array has to be arranged in 3 columns each with 10 elements. I tried to use "Reshape array" but its not working because of array mismatch. Isn't there any function other than "Reshape array"? It doesn't look too flexible to use "Reshape array" for large number of columns.
Please help.
(3,049 Views)
read the help. You are reshaping into a 3D array (size 10x10x10) instead of a 2D array. You should resize the "reshape array" function to only show two dimensions. If you want to 3x10 2D array, one dimension would be 10 and the other 3.
(3,042 Views)
