Strange Binary File Write Behaviour
Something a bit strange going on when I attempt to write data to a binary file. I've replicated the issue in StrangeBinaryFileBehaviour.vi which is attached below...
I'm merely writing two bytes to a binary file yet my hex editor/viewer is telling me I have 6 bytes of data, a screenie of the hex editor dump of the binary file is also attached
Maybe I'm losing the plot and am missing something, forgive it's late on a friday Smiley Tongue
Strokes
(2,134 Views)
Accepted by Strokes
Wire a FALSE to the "prepend array or string size ...?" terminal. The default is TRUE so you get additional bytes, depending on what you wire.
For a 1D array, you would get 4 additional bytes for the array size (I32) and tha's what you are seeing.
(2,130 Views)
I can't tell you how many times that has bit me in the arse.  I understand why the default it TRUE, but I have yet to run into a case where I actually wanted it to be TRUE.
GCentral
(2,121 Views)
