Stupid or Smart Error Bar Plot in LV2010?
A new feature since LV2009/LV2010 is error bar plot. But I have the following problems for this new feature and wondering if anyone can help me solve it:
1: I cannot directly copy error bar plot into ppt or word file.
2: I can export the error bar plot into an image file first, then import it into the ppt/word file, but a big problem is the plot legends are lost. The plot legends are critical information for a plot including multiple cureves. and I cannot find any way to solve it.
Appreciate it if anyone can give me some solutions how I can copy/import the error bar plots including the plot legends into a ppt/word file. Thanks
Alex
(2,853 Views)
When you right-click the plot, in the shortcut menu go to Export>Export Simplified Image, select "Export to clipboard" you can paste (Strg+V) the plot image including the scales into word, powerpoint or other software...
Christian
(2,826 Views)
Unfortunatelly the plot legends will not be included as I said in my original post. 😞
(2,804 Views)
Accepted by Alex Wu
You can use the Get Image method and save it to .png (or .gif or .jpg):
EDIT: Note that because of the way snippets work, the snippet included a control reference. You can simply create the method directly from the control by right-clicking and selecting Create -> Invoke Node -> Get Image.
(2,795 Views)
smercurio_fc
Thanks a lot. Your approach works.
Alex
(2,786 Views)
Alex,
I'm still wondering about why the "default-functionality" doesn't work at your system.
Don't you see scales also when you open e new vi, place an error bar plot and just export the image to the clipboard?
Or does it happen with a certain plot?
Christian
(2,766 Views)
