Subtraction between timestamps
Good morning.
Working with subtraction between timestamp data, I'm encountering seemingly nonsensical behavior, which is becoming quite a headache for the algorithm I'm trying to develop.
Specifically, given that the subtraction between 2 timestamps gives me a double as a result, which effectively represents the number of seconds that elapse between the 2 instants, if I try to convert this number into a new timestamp, the result I get is invariably a hour more than the actual difference between the 2 times.
What is it that's slipping away?
Thanks to everyone who can give me a hand
(21,367 Views)
Accepted by topic author guada_bl
Try to convert just 1 second with and without UTC, this should explain everything for you:
(21,350 Views)
The Time Stamp control/indicator/constant display based on your system's time zone.  I'm pretty certain I saw a nugget about having the Time Stamp display in UTC, which would display the 7 hour that you are looking for.  I just don't remember how to do it at the moment.
GCentral
(21,344 Views)
Great point, Andrey Dmitriev.
Indeed, checking the documentation of the "To Time Stamp Function " it is specified that "time stamp is a time-zone-independent number of seconds that have elapsed since 12:00 a.m., Friday, January 1, 1904, Universal Time [01-01-1904 00:00:00]."
Thak you so much
(21,336 Views)
I just found the trick.  Right-click on the timestamp and choose "Display Format".  Choose the "Advanced editing mode" on the bottom of the dialog and then change the Format String to "%^<%.3X %x>T".  The %^<>T format is described as "Universal time container".   So by just inserting that carrot to the front will make the display use UTC instead of your local time zone.
GCentral
(21,315 Views)
