11-24-2010 10:09 AM
This is probably a trivial question, but how do I switch between 2 string values to be sent to one input terminal of a larger concatonated string function. The values need to be changed every 100ms or so.
mhaque
11-24-2010 10:18 AM
You're right, it's trivial.
Balze
P.S.: Attachment VI LV2009
11-24-2010 11:10 AM - edited 11-24-2010 11:12 AM
Why so complicated??? 😮
You can do this particular string manipulation in a single atomic operation using "Append True/False String" 😄
11-24-2010 11:18 AM
That's why you are a "knight of NI" and a "Labview Champion" and I'm not .
11-24-2010 11:21 AM
Is there a time delay on this VI or is the switching immediate?
If there is a time delay, does it correspond to the whole while loop?
mhaque
11-24-2010 11:27 AM - edited 11-24-2010 11:28 AM
No,
this is (nearly) the same: (Altenbachs is single VI version)
11-24-2010 11:33 AM
The switching happens as soon as the computation completes. There is no data dependency to the wait function, thus both (the wait and the computation of the string) execute in parallel.
For each new iteration, the string will thus update within nanoseconds while the wait prevents going to the next iteration until it has completed.
11-24-2010 12:20 PM
Actually, I was specifically only commeting on your suggestions. The original problem description was:
"...be sent to one input terminal of a larger concatonated string function..."
If if this switchable string goes somewhere in the middle of a huge concatenate string function, you solution might actually be more appropriate. 😄
01-10-2011 09:15 AM
Hi
This VI works, but what does the 200 and the 100 signify?
Sometimes my main VI hangs I believe it could be related to this VI.
mhaque
01-10-2011 09:46 AM
you are right altenbach with the "append true/false string" I can only put the strings to be switched at the end. Since I need it to be in the beginning Balze's solutions gets the job done. However what does the 200 before the "qoutient and remainder" function represent as well as the 100 before the"greater than equal to" function? Are they the time delay? I'm quite confused.
Mhaque
