Switching between VIs in subpanel
I'm having trouble getting a test program to work. I've created two VIs (test1 and test 2) that do simple tasks (like counting or turning on a boolean). I'm trying to switch between the two VIs through a subpanel in the main VI. I'd like to run both vis when called and then switch between them while they run. However, I've been getting errors and I'm at a loss as to what to do. VIs are attached.
One of the errors I'm getting is that the VI references are invalid and I'm not sure how to fix this.
Message 1 of 14
(4,824 Views)
The references you use at the beginning of your program are not right.  Try using a static vi reference (see attached example).
Message 2 of 14
(4,800 Views)
You can also get some help here:
http://www.notatamelion.com/2015/02/09/building-a-subpanel-based-user-interface/
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 14
(4,748 Views)
I have labview 2011 and that attachment is in 2014 so I can't open it Smiley Sad
Message 4 of 14
(4,662 Views)
Try this, it should be formatted for LV 2011.
Message 5 of 14
(4,636 Views)
Sorry, I am having some browser issues.  Try this vi for 2011
Message 6 of 14
(4,627 Views)
I think it is missing from your post
Message 7 of 14
(4,625 Views)
Yeah that works, but it's a VI for a 3d contour haha
Message 8 of 14
(4,609 Views)
Btw, when I try to browse for path, this is all I see. Smiley Frustrated
Message 9 of 14
(4,598 Views)
Accepted by msiwk
Oi, I am having some issues this morning.  Try this vi.
Message 10 of 14
(4,579 Views)
